bednarek avatar image
bednarek asked
Looking for a custom wiring schematic
I am looking for a wiring schematic with wire sizes for the following equipment. Where can I find this.
6-HQST 100W solar panels, 2 sets of 3 in series
1- Victron Multiplus 3000 12v
2-Victron Smart Solar Charger Controls MPPT 100/30
2-Victron Orion-Tr Smart Charger Isolator 12/12/30
1-Victron Color Control GX
!-Victron BMV 712 Smart
1-Lynx Distributor
6-Battle Born 100A batteries in parallel
1-shore Power plug
1-130 amp alternator
wiring
Kevin Windrem avatar image
Kevin Windrem answered ·
Here's a good place to start:
https://www.victronenergy.com/support-and-downloads/systems
This one might come close to your system:
https://www.victronenergy.com/upload/documents/MultiPlus-3KW-120VAC-12VDC-400Ah-Li-VEBus-BMS-generator-MPPT-BMV-CCGX-Orion-Tr-Smarts.pdf
Beyond that, I recommend you find a dealer or someone familiar with Victron components and high energy systems to help with the design.
bednarek avatar image bednarek commented ·
thank you Kevin. I did see this before, but does not give wire gage size any where.
hoeken avatar image hoeken bednarek commented ·
Part of that will depend on your install and how long your cable runs are. I really like this as a quick reference: http://assets.bluesea.com/files/resources/reference/20010.pdf
If you're unsure, might be worth hiring an electrician / installer to go over your design and double check wire size / fuses before you start buying stuff.
