muhammed avatar image
muhammed asked
Solar not feeding all 3 phases
I have installed a 3 phase system (3x15kVA Quattro) with 8x 250/100 MPPT's.
The system however is not utilising the solar for all 3 phases but only for the red phase which is also the master inverter. I also noticed that the "inverter on" LED is flashing on the master unit while the mains on all 3 units are solid.
Additionally it is keeping the batteries charged at all times although I have the SOC set to 30%. The other 2 phases are pulling the power from the grid.
Any ideas?
ESS3 phase
@Muhammed
Phase compensation? are you running ess?
What does the GX device show?
muhammed avatar image muhammed Alexandra ♦ commented ·
@Alexandra
It was actually the fact that the other 2 inverters did not have the assistants loaded on them therefore it was only feeding the 1 phase.
Once I added the assistants to the other 2 units it is all functioning properly.
Paul B avatar image
Paul B answered ·
All fixed as per last post from @Alexandra
