jongor avatar image
jongor asked
BMV-712 shunt chassis ground
Where does the chassis ground go on the shunt?....line side (battery DC-) or load side (all DC- loads)?
Can't believe this isn't in any of the Victron installation documentation.
System is;
solar panel/AC shore power/vehicle battery can all charge the house battery via MPPT and B2B controllers; only want to monitor house battery not vehicle starting battery.
Grounding
wesser avatar image
wesser answered ·
Chassis ground should be connected to the load side of the shunt so that any current going to or from the battery is measured by the shunt. In a non isolated set up the chassis ground will form part of the charging circuit and needs to be measurable.
Ground, earth and electrical safety
