dmeikle avatar image
dmeikle asked
MPPT 100/20 grounding the loads
I am in the process of wiring up my 100/20 mppt controller to a deep cycle battery, 3 x 80watt PV wired in series and a fuse box which will power my accessories including a fridge. I presume I’m correct in thinking that my battery will charge my accessories through the controller when the solar is insufficient? Also do I need to send the ground wire back to the controller from the fuse box or can I ground directly back to the battery? Thank you
MPPT ControllersGrounding
Margreet Leeftink (Victron Energy Staff) avatar image
Margreet Leeftink (Victron Energy Staff) answered ·
Yes your presumptions are correct. Your accessories will be fed by solar power during the day. This will be complimented by battery power during cloudy weather or completely by battery power during night.
The ground wire from the accessories should be connected to the MPPT controllers load output negative.
joeoffgrid avatar image
joeoffgrid answered ·
All negative terminals on my blue solars are same potential. So why not use a common minus?
MPPT Product Page
MPPT Error codes
