I need detailed wiring diagram showing how the excite circuit is wired. Also my alternator goes to my starter then the isolator input. Is this a problem?
Did you ever get any help on this?
I'm having trouble with my Yanmar 4JH45 and the Argofet 100-3 as well.
Their example only has a generic example. Also, the Yanmar diagram indicates there is a wire you should tag to the B+ that provides the voltage to tell the alternator that it's ok to start, but it only blows the fuse when I do hook it up.
Any help would be appreciated.
26 People are following this question.
