the-doon avatar image
the-doon asked
MultiPlus C12/2000/80-30 and Bluetooth remote switch issue
Hi all, having an issue on a new install where the Bluetooth dongle is affecting the remote on/off switching. Everything works fine without the dongle connected but once the dongle gets plugged in the inverter goes into a continuous cycle of switching on and off about every 10 seconds. The remote on/off was set using DIP switches 1&2 and then applying the change by toggling switch 8. Is there any reason why the Bluetooth dongle would affect this?
MultiPlus Quattro Inverter ChargerBluetooth
