scott72 avatar image
scott72 asked
Short Circuit Load Output
Hi, We have made up a 12v 600Ah LiFePo4 battery using a 100/20 Victron Controller. we had 2 x 200W solar panels ready to power a road sign, so all they had to do is connect the PV and the load and they were done, however when our installers installed it to a load, they told us there was no power on the load available, so they used out direct power feed we had built in as a redundancy. We went down a few hours later to check what they had done and there was clearly power available at the load. Is it possible they short circuited it during install on the load or PV and its simply reset itself? We cant check the BT as its installed in a way that is not possible. Any thoughts would be helpful.
Battery Protect
wkirby avatar image
wkirby answered ·
The load output would disable its self if a short circuit or high inrush current ispresented at its terminals.
It would keep testing periodically and if the fault or overload is removed it will switch on again.
