elbsegler avatar image
elbsegler asked
Howto wire Smart Shunt VBatt+ and Aux
Hi everybody
I have installed a SmartShunt on my Sailboot. Normally every load is behind the main switches of the service and engine batterys. should I connect the VBatt+ und Aux directly to the batterys or can I connect them to the output of the correspondent main switch?
Thank you in advance
Sven
SmartShunt
Erik Sporns avatar image
Erik Sporns answered ·
Id advise to put it as close to the batteries as possible, to get a true reading of the batterie voltage with as few voltage drop under load as possible.
elbsegler answered ·
Hi Erik,
the main switches are close to the batterys. Is there any disadvantage if I switch the SmartShunt on and of with the main switch or should it stay on (VBatt+ is connected directly to the service battery)?
Br
Sven
Erik Sporns avatar image Erik Sporns commented ·
Yes sir,
the smart shunt doenst really remember the SOC after being powered down.
See: https://www.victronenergy.com/upload/documents/SmartShunt/Manual_-_SmartShunt-en.pdf?_ga=2.18765754.2016280956.1623908737-1902180410.1623908737
7.10.1 <- Its either start unsynchronized or at 100%
