amidships avatar image
amidships asked
Reusing ground chassis attachment
I am installing and integrating an EasyPlus and a new DC distribution board in a campervan with an existing grounded electric system.
My idea was to attach the ground connection of the EasyPlus to the negative busbar of the distribution board.
Then I would attach this negative busbar to the same location on the chassis where the rest of the equipment is grounded.
Is it a doable solution or should I connect the busbar to its own connection on the chassis?
Thanks
GroundingEasyPlusbusbar
Mike Dorsett avatar image
Mike Dorsett answered ·
I would keep the ground and negative bus on separate connections to the chassis. Then if a connection comes loose, or there is a fault there is better protection.
amidships avatar image amidships commented ·
Thanks for your answer. Just to understand correctly, you suggest having the EasyPlus ground connected to one bolt in the chassis, the negative busbar to a second bolt in the chassis, and keep the existing electrical installation connected to its how bolt in the chassis? For redundancy reasons?
Ground, earth and electrical safety
