duswami avatar image
duswami asked
Grounding with the Lynx Distributor
Can the Lynx Distributor (LD) ground nut be used for multiple ground connections like a bus bar, and then earth ground that connection to my AC service panel. I have a Multiplus II, MPPT Charge controller both chasis grounded on the LD grounding lug. I want to add my battery ground to the LD ground nut and then earth ground the LD to the grounding bus bar in my AC service panel. I'm following local codes but want to be sure this is a permissible connection. Also, I'm using the SmartShunt, would I ground the neg bat terminal or one of the terminals on the shunt instead. Thank you, any insight or opinions (regardless of code) is appreciated.
Groundinglynx shuntbusbar
Lynx Shunt VE Can online manual
Ground, earth and electrical safety
