Does the autotransformer balance the output and the input 120 lines, or just the output, or just the input? I'm confused!
Auto-transformers are a single ended device, it is one transformer winding, typically with a single center tap. More advance models have multiple taps on the 220V end, giving 220,23,240 to 120 at the center. Common terminal is Neutral. There is no balancing.
Victron Autotransformer product page
Victron Autotransformer data sheet
Victron Autotransformer manual
29 People are following this question.
