Máté Őry avatar image
Máté Őry asked
Multiplus-II 3k front panel header
I've just got my new Multiplus II (48V, 3kVA), and while it seems to work otherwise perfectly, none of the front panel leds are lighting up. Opening the case confirmed my assumption quickly: the ribbon cable from the leds wasn't connected anywhere. Could someone provide any documentation about the inside connectors, or just confirm that it should be connected to the header labeled J302 on the control board?20210605-111631.jpg
Multiplus-II
There should be only that connection where the ribbon cable will fit so just plug it in there.
