Paul B avatar image
Paul B asked
GX device enhancement request re Gen Autostart
under the generator autostart feature being voltage.
start parameter no change
Stop on voltage reached Parameter for both normal and quite hrs
could I request that Victron Energy also consider adding a new optional parameter in this stop setting
This being - and stop if charge amps are lower than a set figure
this would be a advantage in that when say 55 Volts is reached then charge amps also would have to be lower than say 10 amps before the start relay is opened
this way the battery is then deemed full as the voltage of 55 volts has been reached and charge amps have dropped below 10amps
currently the only way to partly achive this is if to set the time to run at above 55volts to a figure of say 30 min - and this could be to long or to short
cerbo gx
harold avatar image harold commented ·
You can aslo use SOC% to start / stop
But yes if you start due to voltage, a stop on charging would be logic!
