Noah Taylor avatar image
Noah Taylor asked
How to connect seelevel tank monitor to Cerbo?
I have been following @kwindrem posts and purchased the recommended Seelevel 709 system in the hopes of connecting to my Cerbo. I also ordered from digikey the 3m connector. I used an ethernet cable and cut off one end and am connecting it to the connector. After reading the latest GitHub I installed the newest Cerbo Venus beta update which should be able to read the seelevel. After connecting the Seelevel to the VE Can Port on the Cerbo I am not seeing any tank readings. Is there's some setting I need to change or maybe it's the connector is bad. Anyway any input would be great.
For reference the 3m connector I purchased has labeled 1-4. Using a standard ethernet patch cable the connections are as follows:
1 - white/green
2 - orange
3 - orange/white
4 - green
tank monitor
md-canada avatar image md-canada commented ·
I’m also stumped. I have the CAN bus connected and seem to be receiving packets as per the network status, but I don’t know what else needs to happen to turn these packets into tank readings. I’m using 2.72~2 and using the VE.Can & Lynx Ion BMS (250 kbits/s) profile. Should the device automatically appear in the VE.CAN devices list?
