gschultz avatar image
gschultz asked
Smart Shunt 500A not showing battery state
My Smart Shunt in my 2 battery RV setup (wired as below) is not remembering the last charge setting when the bluetooth connection is broken. For example, batteries are 100% charged and the Android Victron App is connected to the shunt. In the RV, I run out both slides and the fridge is on (draws about 7Ah) overnight. In the morning I start the app to check the remaining battery capacity and it shows 100%. How the heck is that possible?!? I KNOW that I've drained some of the battery overnight. What am I doing wrong?
SmartShunt
Does your fridge work with the battery cut-off switch turned off?
Paul B avatar image
Paul B answered ·
Check the charged voltage setting
my guess is that the battery voltage is higher than this setting if it is then the SOC will stay at 100%
on a 12 volt system the voltage is usually set at 14 volts, theis is the tripper for the display to change to 100% when the battery is full
also charged detection time and tail current affect when its triggered as well
Also the battery ground is not connected correctly
