Bryan Buttigieg avatar image
Bryan Buttigieg asked
MPPT 100/15 battery current higher than solar current?
c357813c-2710-4fd1-8368-4d9399fc8e8f.pngTrying to understand the reason why battery current on my MPPT 100/15 is consistently showing as being higher than solar current. My understanding with the 100/15 is that a positive battery current number means current going into the battery and a negative means current leaving. But how can current going in to the battery exceed what is coming off the panels?
100Wx2 panels. In series. A/C charger off. BMV 712 monitor and Blue Sea charging relay.
MPPT Controllerscharger
That's physic :-) P = U x I
37,79V x 0,5A = 18,89W
13,61V x 1,3A = 17,69W
(1,2W conversion loss)
higher voltage means less current for the same power.
lower voltage means higher current for the same power.
greendovefarms avatar image greendovefarms commented ·
Nice work !!!!
gro avatar image gro greendovefarms commented ·
MPPT solar charger has a a dc to dc converter. Therefore as shown above the current and voltage either side of the converter don’t have to be the same. But the product of current and voltage is power and that does have to be the same (minus efficiency losses)
MPPT Product Page
MPPT Error codes
Chargers.
