It appears from several posts that the screen information/display can be customized. I'm not a computer programmer, so don't want to attempt it on my own. Has anyone created a templet similar to the screen info/design for Raymarine?
When you use the VE.Can connection to connect to the Raymarine Lighthouse 3.3x the Cerbo information can be integrated in the Dashboard screens of the Raymarine.
It is possible to use a custom logo onto the Boat & Motorhome page.
Type the following address into the web browser of a device connected to the same network. Using this address as a template: http://venus.local/logo.php or http://[ip-here]/logo.php (inserting your device’s IP address between the square brackets). The IP address can be found by going to Settings -> Ethernet or Wifi. Once the page is loaded, Choose an image file from your device. Re-boot the GX device.
From the manual:
28 People are following this question.
