Robert Chabot avatar image
Robert Chabot asked
How to wire two separate battery bank to Victron battery monitor?
I have four 6 volts deep-cyle battery, two on starboard and two portboard. (see the schéma below). I was thinking that my battery wiring was, first in serie, then second, in paralel, but now I’m not sure. How would you discribe this battery wiring?
For the Victron monitor battery purpose, the ground wire, ( black one)coura of each bank are connected directly to the shunt battery side, then the load side of the shunt is connected to the negative bus bar.
But the Victron monitor show me only charge and current and, bizarry, the charge information was alway the same as my Victron Mppt.
So, what is wrong in my actual wiring ?
Regards
victron community
