cyan avatar image
cyan asked
Cerbo GX - PLC (automation)
When I saw the cerbo GX with relays and inputs I though ooooh it will be a plc, but out the box is a bit limited, relays are not really programmable and not a lot you can do with inputs....
I was hoping that this with the touch 50 would take the place of the outdated and broken motorhome control centre....
Is it possible to do the following?
Trining heating on/off on a time schedule and/or if temp drops below setpoint
Using victron touch50 to override heating on/off
Touch 50 to Turn lights on/off
Run pump for fresh water tank when pressure is low.
Also only 2 relays... is there anything out there that connect to victron system to provide more relays ?
cerbo gx
cyan avatar image cyan commented ·
Thanks, now that looks more like what I want to do. Thanks for your response.
Do you know what if anything I can connect to the cerbo GX to add more relays?
