fei avatar image
fei asked
Please help, Tank lever sensor with Venus on RPI 3b+
I have follow all the steps below and I still could not get the analogy device in the device list. Would appreciate if anybody could help point me to the right direction
My setup
Raspberry pi 3b+ with expander pi
Firmware 2.51/2.66/2.70
Have not hock up with tank level sensor yet.
Status
No device showing up on device list
No iio folder under /sys/bus
Steps I followed
1 copy the DTB file over from here https://github.com/aaronsb/victronvenussupport/blob/master/mcp3208-overlay.dtb and save into /u-boot/overlays on the RPI. -> OK done
2 add line: dtoverlay=mcp3208:spi0-0-present to file /u-boot/config.txt -> OK done
3 opkg install kernel-module-mcp320x -> got message: No packages installed or removed.
=> opkg list-installed pointed out that kernel-module-mcp320x-4.9.80 was already installed.
4 Rebooted
5 copy manually contents of dbus-adc.zip to /opt/victronenergy correct path should be /opt/victronenergy/dbus-adc not /opt/victronenergy/dbus-adc/dbus-adc!
6 chmod 755 /opt/victronenergy/dbus-adc/start-adc.sh -> OK
chmod 755 /opt/victronenergy/dbus-adc/dbus-adc -> OK
chmod 755 /opt/victronenergy/dbus-adc/service/run -> OK
chmod 755 /opt/victronenergy/dbus-adc/log/run -> Path seems to be wrong changed to /opt/victronenergy/dbus-adc/service/log/run => OK!
touch /var/log/dbus-adc -> OK
ln -s /opt/victronenergy/dbus-adc/service /service/dbus-adc -> OK
7 Reboot
8 Various tanks are now reported on the "Mobile Page" and 5 new items appeared in the Device List.
tank monitor
