heinzie avatar image
heinzie asked
Acceptable midpoint deviaton value?
Goodmorning
I have 2 x 2 victron agm 220 ah in series-parallel for 24 volt 440ah.
My midpoint deviation measured by smart shunt is around 0 to 0,3 % maximum.
This is up to 0,0 to 0,07 Volts difference.
When batteries are charging and in absorption stage the deviation is up to 0,7-0,8%
After charging is finished, deviation slowly goes back to 0 - 0,2
What is an acceptable value for this?
My alarm is setup around 2 percent by deviation (standard)
All is connected by busbars and equal cable lengths.
Setup is protected by battery ballancer.
Batteries are 2 weeks old and setup is as wel.
Can i expert higher or lower values?
Best regards and thanks in advance!
MPPT Controllersbattery chargingBMV Battery Monitor
markus avatar image
markus answered ·
Hi Heinzie,
did you fully charge your batteries before you put them in a serial connection?
When you buy new batteries, they are most likely not on the exact same SOC, so it's always a good idea to charge them to 100% SOC BEFORE you use them in a serial string.
BR
heinzie answered ·
Hallo Markus
Yes i did indeed
I notice the deviation is getting lessen now, around 0-0,1 percent but wh3n charging still up to 0,8 max
Thank you for your answer
