bb22 avatar image
bb22 asked
SmartShunt travel trailer installation
I am installing a 500a SmartShunt on a travel trailer. The battery negative is connected directly to a chassis ground. No other connectors are attached to the battery negative terminal. Can I just install the shunt between these two connections or do I have to physically wire all loads and chargers to the system minus side of the shunt?
SmartShunt
marvs avatar image
marvs answered ·
Apparently the travel trailer is using the chassis as a return for ALL 12V connections. you should be OK connecting the shut between the battery negative terminal and the chassis..
