Hi Community.
I would like to know if it,s possible to use a tank GX 140 in combination with analog tank gauges in this case from Wema.
See schematic below.
Hi Community.
This sensor seems to be a resistor based one (0-190Ohm) and can be connected directly to a Cerbo.
The GX tank 140 is for sensors with 0-10V or 4-20mA.
But I can't say if a parallel connected gauge will influence the reading.
30 People are following this question.
