Will my 2000 watt inverter work with 565 w solar panels, 50 amp controller and 3 100ah battleborn lithium?
Considering you are using 3 batteries I would guess that your system is 12v.
On a 12v system a 100/50 will handle around 700 watts from the solar panels.
I noticed that you said panels not panel so would like to confirm how many panels and what the specifications are for them (Voc,Vmp,Isc and Imp).
A 2000w inverter will draw a bit over 150A @ rated output so should be ok from those batteries.
More details about your system would allow me to give you a better answer.
47 People are following this question.
