rvjeepguy avatar image
rvjeepguy asked
GX Tank 140 Sensor Voltage
I have 3 tank sensors that require a 10-12V power supply. On the GX Tank 140 it looks like channels 1 and 2 use an external power source. Does that mean that I need to purchase two GX Tank 140s? Or, can channels 3 and 4 be used with ground only using an external power supply?
tank monitor
Kevin Windrem avatar image
Kevin Windrem answered ·
You should be able to power all 4 sensors from an external power supply.
