milad avatar image
milad asked
Can I connect BMV712 VE.Direct port directly to Rpi GPIO?
Hello everyone,
I have plan to use raspberry pi to monitor my batteries through BMV712.
I would like to use a python code to monitor the bmv outputs instead of having victron OS on my raspberry pi. I need my raspberry pi for other purposes as well.
I was wondering if I can connect VE.Direct port to GPIO directly.
If I can, would you able please to guide me for its pin-out?
Thanks in advance,
Milad
BMV Battery MonitorRaspberry Pi
trygvelu avatar image
trygvelu answered ·
It should be possible, you just need to figure out how to configure the UART port for the gpio pins.. I would suggest to use a USB-UART adapter, preferably with some isolation. Or even better, use the Victron USB-VE.Direct cable.
milad avatar image milad commented ·
Thanks a lot
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
