underpar12 avatar image
underpar12 asked
No ac power .
Just connected my mppt 100_50 up for the first time .I jave 230 volts in the rcd .but no ac out .seems like I'm missing something simple I hope .
EasySolar All-in-One
Kevin Windrem avatar image
Kevin Windrem answered ·
Tell us more about your system. A Victron Smart/Blue Solar MPPT won't create AC on it's own. I'll create DC to charge a battery, then an inverter will convert the battery's DC to AC.
Mike Dorsett avatar image
Mike Dorsett answered ·
If you have the Easy solar with the 100/50 Mppt, and do have 230V ac on the rccd, this check to see if the rccd is closed, and if it is, then you should have the same ac volts on the output. press the test button to check that the rccd operates.
