Please can you implement a feature where if power exported is greater than xxx for period yyy then venus contact closes . Similarly when power is less than xxx - hystereis then relay open.
47 People are following this question.
Multiplus-II with Raspberry Pi and ESS Mode 3, python script for control loop
Getting Chargestate over Modbus in Inverter mode
dbus item com.victronenergy.system /Ac/ConsumptionOnInput/L1/Power missing modbus registry
Guide for Daly BMS CAN communication with Venus OS on RPI and Multiplus II
Recommended resource to look at for adding to the Venus GUI?
