dale-shacklock avatar image
Call MPPT 75/10 solar stats with Pi
Hi
Little bit of a noob but hoping someone can guide me or point me to an already existing page...
Currently using a Pi 4 which is powered by solar and running Raspbian OS with CCTV software (Nx Witness)...
what I'm wanting to know is, can I create a script that will allow the Pi to send a ping/call to the MPPT 75/10 (via USB) and in turn the MPPT fires back the battery, load and incoming solar stats....im then wanting to use these stats to monitor the remote units.
Our software doesn't work along side with the Venus images etc
Thanks Guys
mppt smart solarRaspberry Pi
miked avatar image
miked answered ·
This is the code I use, and you are welcome to use it as an example:
com2 = serial.Serial('/dev/ttyUSB0', baudrate = 19200,parity=serial.PARITY_NONE,
stopbits=serial.STOPBITS_ONE, bytesize=serial.EIGHTBITS)
def long_to_short(long_byes):
temp = float(long_byes)
hi_byte = int(temp/65536)
lo_byte = int(temp-65536*hi_byte)
#print("152",long_byes,hi_byte,lo_byte)
return(hi_byte,lo_byte)
def readbytes2():
rxstring = ""
try:
while int(com2.inWaiting()) > 0:
byte1 =(ord(com2.read(1)))
rxstring +=(chr(byte1))
except Exception as e:
print("rxmsg",e,com2.inwaiting())
#print(rxstring)
nl = rxstring.find("PPV")
fl = rxstring.find(chr(0x09),nl) #Find the tab after "PPV"
nl2 = rxstring.find(chr(0x0d),fl) # find the new line after the data
if nl != -1:
pvp3=rxstring[fl+1:nl2+1]
print("PPV",pvp3)
try:
ppv = float(pvp3)
pvp_h,pvp_l = long_to_short(ppv)
print(97,pvp3,e)
# if fxfield == "V":
nl = rxstring.find(chr(0x0d)+chr(0x0a)+"V")
fl = rxstring.find(chr(0x09),nl) #Find the tab after "V"
if nl != -1:
print("V",pvp3)
#789 sf 10 uint16
try:
ppv = float(pvp3)
print(112,pvp3,e)
# if fxfield == "I":
nl = rxstring.find(chr(0x0d)+chr(0x0a)+"I")
if nl != -1:
print("I",pvp3)
try:
ppv = float(pvp3)
if ppv <0:
ppv+=32768
print(131,pvp3,e)
nl = rxstring.find("H19")
if nl != -1:
print("Yield tot",pvp3)
try:
ppv = float(pvp3)
print(145,pvp3,e)
# if fxfield == "H20":
nl = rxstring.find("H20")
if nl != -1:
print("Yield",pvp3)
try:
ppv = float(pvp3)
print(165,pvp3,e)
nl = rxstring.find("H21")
if nl != -1:
print("Max power",pvp3)
try:
ppv = float(pvp3)
print(174,pvp3,e)
nl = rxstring.find("H22")
if nl != -1:
print("Yield -24h",pvp3)
#772 sf 10 int16
try:
ppv = float(pvp3)
print(139,pvp3,e)
nl = rxstring.find("H23")
if nl != -1:
print("Max power -24h",pvp3)
try:
ppv = float(pvp3)
print(202,pvp3,e)
nl = rxstring.find("ERR")
if nl != -1:
print("Error ",pvp3)
try:
ppv = float(pvp3)
print(202,pvp3,e)
# if fxfield == "VPV":
nl = rxstring.find("VPV")
if nl != -1:
print("VPV",pvp3)
try:
ppv = float(pvp3)
print(156,pvp3,e)
nl = rxstring.find("HSDS")
if nl != -1:
print("Day No",pvp3)
#772 sf 10 int16
try:
ppv = float(pvp3)
print(156,pvp3,e)
Not too pretty, and no warranty. ppv is used for the extracted variable in each block, so you need to do something wiht it before moving onto the next block. Have fun. There is no "simple" call to do this. This code decodes the continuous ASCII output from the usb com port.
miked avatar image
miked answered ·
This is easily done using the VE-direct/usb adapter to the pi, and can be programed in python, referring to the VE direct hex protocol. Or you can just read the ASCII stream that is continually output from the MPPT. If you just want to read the parameters, the latter is the easiest - but it does mean a lot of string processing in your program.
There are documents available with the protocols:
https://www.victronenergy.com/support-and-downloads/technical-information
(scroll down to VE.direct)
And there is the modifications space:
https://community.victronenergy.com/spaces/31/index.html
Hey mate
Ive had a look and i see there are projects similar however none that are able to point me in the right direction of just a simple call action.
I am a little noob at this and ideally we'd like a simple text command we send to the Smart Controller and receive a response. Either by SSH or directly from the Pi itself
