mdr avatar image
mdr asked
Equivalent of mpptdump.exe for linux
my goal is to update the firmware of a MPPT (75/15 smartsolar) connected to a raspberry pi4.
I managed to do it using a serial port redirection to a windows computer with mpptdump.exe but I will really like to do it directly from the raspberrypi.
I found this documentation about the venus OS that allow to do it with the dup tool. But I am unable to make it work on my raspberry.
https://github.com/victronenergy/venus/wiki/commandline---operational
dup -s /dev/ttyO2 -f filename.dup
I copied the /usr/bin/dub from the latest venus image for rpi4 but it's not enough to make it work, I guess I am missing librairies and dependencies?
Any clues?
Best Regards,
Martin
MPPT SmartSolarVenus OSRaspberry Pi
@mdr
Moving to modifications space, all the RPi stuff goes there.
d-ferdi avatar image
d-ferdi answered ·
root.txt
hello,
extract/copy the hole venus-os-image to a dir at the raspi and use chroot dir to get full access to all programs in the venus-os.
but i don't know, if all programms which use debus work if you don't use dbus in chroot.
it can be important to mount --bin /dev /dev/shm /sys /proc to the dirs in chroot before you start chroot.
i insert my script for starting root-environments.
goodby
root.txt (1.0 KiB)
mdr avatar image
mdr answered ·
thank you d-ferdi for your answer,
I finally found an easier solution that allow me to run a 32 bit executable on a 64bit debian:
dpkg --add-architecture armhf # ignore the warning!
apt-get update
sudo apt-get install libc6:armhf libstdc++6:armhf libpthread-stubs0-dev:armhf
get the /usr/bin/dup from raspbery4 venus image
http://updates.victronenergy.com/feeds/venus/release/images/raspberrypi4/
and copy it to /usr/bin on your raspberry and make it executable:
chmod +x /usr/bin/dup
and finaly:
It work like a charm but it doesnt update the bluetooth firmware.
