dwiea avatar image
dwiea asked
Smart Battery Protect settings for Superpack 100ah
I have a 12/24v 100A smart battery protect and a 100ah SuperPack 100ah lifepo4 battery. I was wondering if anyone can tell me what the settings should be for the shutdown and restart voltages should be. The spec sheet says 'End of discharge voltage' which is 10v but is this the correct value and if so what would be best for the restart voltage?
Lithium BatteryBattery Protect
shreeyash avatar image
shreeyash answered ·
Hello @Dwiea
If you are using 12v LiFePO4 battery, you should program Battery protect to program number 8(Under voltage shutdown: 12V, Under voltage restart: 13v). This program is ideal for LiFePO4 and at around 12v, battery will be at around 10% SOC.
You could also refer manual for more options: https://www.victronenergy.com/upload/documents/Manual-Smart-Battery-Protect-12V-24V-65-A-100-A--220-A-EN-NL-FR-SV-DE-PT-ES-IT-TR.pdf
Hope this helps.
Best,
Shreeyash
