It appears you can't just post a general share, instead you have to ask a question that others may or may not answer. So I'm posting my question and will turn around and answer it.
Ok, has anyone connected a LED/Buzzer to their Battery Protect?
For some reason, I had a hard time figuring this out. I read the manual, looked at the pictures, but the mental light bulb just didn't turn on for me (nor did the external alarm). Eventually I figured it out.
Here are pictures that show how I connected my SmartShunt & Battery Protect. Maybe this will help someone else.
Everything Connected, but no load.
Load Turned On
LED Alarm On/Buzzer buzzing
What exactly was your problem?
Your setup looks exactly like the manual shows.
I don't see anything wrong/confusing in the manual.
I fitted a buzzer to my Battery Protect, very simple to do as show in the setup video.
Which setup video? I watched a number of videos & didn't find one showing how to connect a LED/Buzzer.
Wait a moment. The manual for the BP-65/100/200 tells a different story about the LED/Alarm output. When i see you hardware the LED is connected to the LOAD side of the BP. The manual show different. Please clear THIS.
28 People are following this question.
Smart BatteryProtect BP-100 Remote doesn't work
Arogfet 24/12 bat isolator wiring question
Battery Protect 12/24 100A doesn't work properly, does it?
Can I use a Victron Battery Protect to Cut solar input on my motorhome when the engine is running?
Battery Protect not engaging under load? Causes high voltage condition.
