southsideph avatar image
southsideph asked
ON/Off Grid use case
Hi
Working on proof of concept for our exhibition trailer.
Background
Normally undertake a number of outdoor exhibitions, as these are starting again looking to a hybrid energy solution as a lot of venues a actively banning use of generators so either use provided EHU or go to alternate energy.
Using the following as a use case
https://www.victronenergy.com/upload/documents/VE-direct-drawing-with-Phoenix-charger-12-50-1-inverter-375W-Li-Batt-smallBMS-MPPT-100-30-Orion-Tr-smart.pdf.
Kit includes
  • 100/50 MPPT
  • 200W Solar arrays
  • Smart Shunt 500
  • Smart Battery Protect
  • Phoenix Inverter 800
  • Orion TR 12/12/30 Isolated
  • Venus
Question is around grounding.
Phoenix in the above use case is bonded to the -ve busbar I am assuming the bus bar is also grounded to the chassis to EHU power
I'm assuming the 375/800 has the earth connected to the N of the AC output by the internal jumper.
Rgds
MPPT ControllersMPPT SmartSolarPhoenix Inverter
