jimbo avatar image
jimbo asked
Pylontech UP3000 & BMV settings
Just setting up the BMV 702 for use with the Pylontech UP3000
Are these settings ok?
1 Capacity: 518AH (7 units @ 74AH)
2 Charged Voltage: - 52.2V (0.2V under charged levels of VDCC capped voltage of 52.4V)
3 Tail: 0.4
4 Time: 3min
5 Peukets: 1.1
6 Efficiency: 95%
BMV Battery MonitorPylontech
Hi, I recommend to not have a BMV added to a Pylon.
the Pylon already has state of charge, and it will work better than the BMV.
having a second SOC monitor mostly adds confusion: “why are the percentages different?!”.
all the best, Matthijs
jimbo avatar image jimbo commented ·
ok thanks Matthijs.
The CCGX SOC% will be taken from the BMS automatically? or do i need to set it manually? i seem to remember a setting in the CCGX somewhere that specified what to use for SOC.
if the BMV is left connected will it affect operations?
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ jimbo commented ·
Hi, If you have both, you’ll have to choose one manually. If you’d have inly the Pylon, the default setting “auto” will work for you. I dont think having the bmv poses issues, however: we dont test nor design for such combination.
Victron Pylontech battery compatibility guide
