hiaslgruber avatar image
hiaslgruber asked
Can I use a Multiplus 1 like a Skylla IP44 as additional charger in a Multiplus 2 system?
The following post is talking about the possibility to use a Skylla IP44 charger as additional charger in a Multiplus 2 system without the need of any synchronisation:
https://community.victronenergy.com/questions/23004/charging-with-a-skylla-ip44-and-multiplus-inverter.html
Can I substitute in this case the Skylla with an Multiplus 1 in Charger-Only-Mode?
Multiplus-IIMultiPlus Quattro Inverter Charger
Alexandra avatar image
Alexandra answered ·
@hiaslgruber
In theory you can yes, in charger only mode.
As the article says make sure your wiring can take it. And you are not overamping the battery.
