nono-gps avatar image
nono-gps asked
ve.net bpp / easysolar (multiplus)
(google traduction)
Hello
I am in the process of installing my equipment bought two years ago.
-easysolar 24/1600/40
-ve.net blue power panel
 everything is working fine, charging, 12v, 220v
the multiplus and the bpp does not communicate impossible to display the information.
 I own the MK3 and I have config3, ve flash
I have already tried to reinstall the firmware of the multiplus without success.
firmware: -bpp, 0x0400                 - multiplus, 2616413.vfd
 CAN I MAKE THEM WORK OR INCOMPATIBLE ???????
 Thank you,  arnaud
 the multiplus
bonjour
je suis entrain de proceder a l'installation de mon materiel acheté il y a deux ans.
tout fonctionne correctement, charge, 12v, 220v
le multiplus et le bpp ne communique pas impossible afficher les information.
je possede le MK3 et j'ai ve config3, ve flash
j'ai deja essayé de reinstaller le firmware du multiplus sans succes.
PUIS-JE LES FAIRE MARCHER OU INCOMPATIBLE???????
Merci a vous,
arnaud
le multiplus
EasySolar All-in-Oneblue power panel
Paul B avatar image
Paul B answered ·
to use a Blue power monitor. Download the firmware 2616159.vfd and install it using the MK3 and the Blue power unit will then work
If you need the features in the latest firmwares then you will need a smart shunt and a GX device
as the Blue power units have been replaced with the new range
nono-gps avatar image nono-gps commented ·
Merci pour votre aide,
je vais essayer cela dans l’apres-midi
EasySolar 1600 product page
EasySolar-II GX 3000 & 5000 product page
