we use the shunt directly on busbar, and then the build quality is an problem.
That is the bottom side, where the (now removed) baseplate is attached.
That surface is not used for electrical contact, so it's only a cosmetic issue.
You should not attach the busbar on that side. The monting holes for the busbar or wire lugs are not there.
For reference:
25 People are following this question.
