mr-simon avatar image
mr-simon asked
Too much PV power input MPPT 100/30
I own a MPPT 100/30. The data sheet says if too much PV input power is installed, it will be automatically limited. Is that true? Under best conditions my setup would deliver 700 Watts. Question: Is there any damage possible or will the input power be limited to 440W (12V) ? All other parameter are in specification (~84V, 11A) Can I run this setup?
AC PV Coupling
netrange avatar image
netrange answered ·
Important for the Setup is the Maximum Peak Voltage of your solarinput ... 84V sounds good ... and the Maximum Current of 30 amps is Not reached ...
