I would not run the pump directly trough the Cerbo relay.
But you can enable a "larger" relay with the Cerbo relay.
thank you for answer Matthias but what do you mean by a lager relay
The typo might be misleading.
"laRger"
Maybe this isn't even a typo:
In Germany, a jug of "lager" is mostly larger than anywhere else. :o)
28 People are following this question.
