traveltechrv avatar image
traveltechrv asked
multiplus-ii 12/3000/120-50 2x120v - Mounting issues
img-1367.jpgHello - I have an RV with a compartment that is 23" tall. The inverter is 22" tall, so it will not fit. Is there any reason why the device cannot be mounted in the orientation I have taken a picture of? Also, can it be mounted flat on its back on the rubber feet if I was to put it on a small table laying down?
Is there any other mounting options available other than the picture frame style hanger that is on the inverter.
Thank you! - Travel Tech RV Delray Beach FL
EasySolar All-in-One
Kevin Jesser avatar image
Kevin Jesser answered ·
Hi, I was just wondering if you ever received any advice regarding mounting your inverter on its side. Or if you actually did do it, and did you find any issues.
Regards
KevinJ
cb-otb avatar image
cb-otb answered ·
Just curious how this orientation worked out for you?
