svalvasori avatar image
svalvasori asked
Cerbo Temperature Sensor Range
What is the maximum temperature the Cerbo will read with the required sensor? I want to measure shaft (~100-115 deg F) and engine temperature (180 deg F)?
cerbo gx
Hi @svalvasori,
the temperature range for the sensor (LM335) is specified as from -40°C up to 100°C.
LM335 Data Sheet
Matthew Hennigar avatar image
Matthew Hennigar answered ·
Hi Victron... Have you considered offering a min temperature range of minus 40c on the cerbo gx? The sensor is good to that min temperature however cerbo gx reports an error below minus 20c. This is incredibly inconvenient when trying to use a cerbo GX to monitor the freezer temperature at my off-grid cabin.. it trips the alarm when the temperature drops below minus 20. Rendering the alarm function useless
Good suggestion @mhennigar
The change has been made and included in Venus beta v3.10~7 for testing.
Hi @mhennigar,
I've passed on the suggestion, thanks for making it.
outstanding both in response and in turnaround time. Thanks!! You're not like most hardware vendors.
