I plan to install an EasySolar. My question is if the AC outputs will shut down at low battery voltage and if thos is adjustable?
Using VE Configure this can be adjusted
Thanks for your answer! Is this possible for all 3 different AC putputs seperatly? And one more question: here in Sweden we might be without any solar for some winterweeks. Will the inverter shut down itselv saving the battery? In the datasheet I see 10 -20 W in standby. That can easyly be 2 kWh per week. Will the MÅpT part in the EasySoar continue working? Thanks for helping an unexperient colleague! Klaus
29 People are following this question.
