daineric avatar image
daineric asked
BlueSolar 75/10 MPPT shuts down when I plug in VE-Direct Cable
I typically leave the VE-Direct USB cable plugged into my charge controller so I can easily plug it into my Android phone and monitor the battery and charge when I'm camping. This weekend I tried to plug in the phone and couldn't get it to find the device. I also was not getting any power out of the battery.
When I unplug the cable from the charge controller, I get power out of the battery again and the lights on the charger show that it is charging. But as soon as I plug the cable back in, I lose power and both (blue and yellow) lights on the charger illuminate solid.
Any ideas on what is wrong?
MPPT Controllersmppt charging
helios-harvester avatar image
helios-harvester answered ·
Can you make sure that the pins inside the connector of the charge controller are not bent and make contact with each other ?
Because this reminds me of a short on the data bus
Also what Cable and USB to serial you use to connect your charge controller to your phone ?
Thanks
The Harvester
MPPT Product Page
MPPT Error codes
