Paul B avatar image
Paul B asked
Assistant - General Flag stopped working
I have a Multiplus II 48/5000 (Early H/W version)
Venus GX 2.65~8
Now I was on FW471 (all working fine and have just upgraded to FW481 (using the new remote Upgrade in beta test just to test the new feature, - I dont think the new update feature procedure is the cause however I mention it just in case)
Since the FW update to 481 it seems that the General flag is not working very well
I can no longer get the AC1 IN to open when using general flag
The Fig 1, Is my Normal assistant settings
I have now removed ALL assistants except the General Flag set to ignore AC input 1
As you can see in Fig 2 AC 1 IN is fully active and AC1 IN is not turning off
Now last night on the new 481 Fw AC1 IN did turn off at 7pm (thats when the update occured to 481) (this bought the issue to my attention) (Flat battery bank this morning)
The assistants for ess and the solar current sense are working fine (when installed)
Any one got any ideas ??? as to why the general flag is not working.
I have not got FW 471 here at home so cant roll it back and test.
if anyone has a copy of FW471 2626471.vff please send it to me
Fig 1
Fig 2
Assistants
Al avatar image
Al answered ·
Do you normally have the generator start stop assistant loaded to trigger the AC ignore general flag, and it didn't work then? If not I think general flag needs it.
Paul B avatar image
Paul B answered ·
SORTED and fixed
helps if you put a reverse relay in with a open command to then open the relay
General flag
Set on
when Aux input 2 is open for 1 second
