Finishing up my 12/3000/120 install and was wondering if I need the t-sense installed if I already have bmv 712 with temp sensor and a smart dongle for multiplus? Will the bmv tell the multiplus the temp?
Its easyer to use the temp sensor that comes with the muliplus. If you dont use it then you may het the temp light coming on warning that there is a sensor fault
If you have the multiplus set to Lithium then as far as I know the temp sender is no longer needed (Not 100% sure on the lithium option bit)
Victron temperature sensor disambiguation table - which product supports which sensor
23 People are following this question.
