Peter Buijs - NL avatar image
Peter Buijs - NL asked
Cerbo VECan SmartShunt 500 to Raymarine
My setup is
Axiom Plus 12 with Lighthouse 3.13.103
Cerbo 2.63
SmartShunt500
It all works with the HTML5 App
Now I want to configure it working via VECan
When I look in the Axiom > Network I see a
- Cerbo
- Unknown n2k device SmartShunt 500A
- Unkonwn n2k device SmartShunt 500A/50mV 0000501
The Service battery Volt-Amp-SOC-TimeLeft are displayed correctly but the Starter battery does not show.
I am aware of these topics, but I need some advice how to change the data instances in the Cerbo
cerbo gxVE.CanNMEA 2000 - N2K
bathnm avatar image
bathnm answered ·
You should not need too change any data instances, if the battery starter voltage is on the second input of the Smart Shunt.
Have you told the Axiom that you have two batteries. It is in the system settings somewhere, not at my Axiom so cant oroivide any more guidance than that.
The only time you may need to modify the data instance is when you have multiple Smart Shunts and/or BMVs
4 comments
Peter Buijs - NL avatar image Peter Buijs - NL commented ·
@Bathnm Now that I have told the Axiom that I have 2 batteries all the values of the SmartShunt are shown over the VECan<>NMEA2000 interface
Thanks!
bathnm avatar image bathnm Peter Buijs - NL commented ·
No problems. It caught me out for a while. Raymarine was really great at helping find the issue. I was trying to see 4 different batteries.
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ bathnm commented ·
Hi Peter (or Mark ofcourse) do you have a photo or other explanation of where to set that up in the Raymarine?
Sounds like we should add it here:
https://www.victronenergy.com/live/venus-os:mfd-raymarine#nmea_2000
pepe1395 avatar image pepe1395 mvader (Victron Energy) ♦♦ commented ·
@mvader
In order to setup the number of batteries, you have select in the home screen Settings,
then Boat details
and scroll down until you reach the field Num of batteries.
That's it.
Ciao!
