johan-granqvist avatar image
johan-granqvist asked
Can i use one of the outputs of a Argofet isolator as a connection stud?
My argofet sits between the batteries and the alternator. I want just one one cable connected between the Argofet to the positive battery post of the starter battery. Can i use the output stud on the argofet to connect a cable to the engine starter? I will save some meters of cable and fuse the cable going from the batteryargofet.jpg
Argo FET Diode
Vance Mitchell avatar image
Vance Mitchell answered ·
I would think that the ArgoFET would require a significantly smaller fuse than what would be required for starting loads.
Another option would be to use the starter motor positive post as the connection point for a fused wire to the ArgoFET battery connection. This is assuming that the ArgoFET is reasonably close to the Starter motor.
Otherwise I would install a distribution busbar near the ArgoFET and fuse each wire accordingly.
This last option would allow for some future expansion if you ever need to add more devices into the sytem.
johan-granqvist avatar image johan-granqvist commented ·
I will use 70mm2 cable from alternator to battery to prevent voltage drop, and a 35mm2 from the starter to the argofet. But will put a fuse next to the battery that will hold when starting the relativly small engine. The Fuse will be around 80 amp. The alternator is delivering 60 amp. It should work. I was just a little bit afraid that i somehow could hurt the argofet when starting the engine..
