sailwatch avatar image
sailwatch asked
Easy Plus 230V installation in RV Camper Van
Hi. I bougt an Easy Plus 1600 Inverter. Unfortunately i dońt get any support from my dealer (greenakku.de) so íll try here...
Actually the 230V system Setup should be quite simple... but to be sure i need some help.
(insatllation mobile in a Camper)
is it sufficient to connect the AC in correctly (GND, N, L1) and the AC 1/2/3 correctly to the users and add one Ground wire to the chasis of the car from the bolt on the Easyplus.
Thats it?! Or do i have to add any additionally safety.
Thanks for help!!
EasyPlus
djrmml avatar image
djrmml answered ·
Its adviced to put a breaker after the inverter.
Also read the easyplus manual, page 11 (EN) for more information on the 230v side.
sailwatch avatar image sailwatch commented ·
Hi, thanks for the reply. Where would you put a breaker? In the 12V part i‘ve installed a 200A breaker... but the 230V part additional breaker?
My question was refering more to the ground wiring... (what do i have to connect to the chassis of the car, only the bolt of the housing of the easyplus?)
