ers avatar image
ers asked
connecting 2 different sized mppt charge controllers connected to 1 single cable coming from parallel connected solar panels
  • how efficient would it be to connect 2 different sized mppt charge controllers connected to 1 single cable coming from parallel connected solar panels ? to be clear: one cable will come from solar panels (6 panels) and will be connected to 2 seperate mppt charge controllers in parallel (the 1 combined cable carrying all 6 panel currents). the reason i’m asking is 1) 1 mppt controller is not big enough to handle all parallel connected panels 2) i already have one cable run through from panels, i don’t want to run another cable from the panels and want to keep only one cable if this setup would make sense.
MPPT SmartSolarSolar Panelmppt charging
This is not a supported configuration. You can only connect 1 MPPT per solar array.
You will need to split the panels up so that they are not connected in parallel, and run 2 sets of cables down independently, one for each MPPT.
ers avatar image
ers answered ·
not supported means can’t be done ? i really don’t want to run another set of cables down to mppt what else i can do?
Don't even try this.
MPPT product page
VictronConnect manual
PWM or MPPT
MPPT calculator
MPPT codes
