5teve avatar image
5teve asked
Multiplus 12/3000 cannot be switched via VEbus / Mk3 / VenusOS
OK I'm trying this again a year on.. life got busy and now after an AGM dying i'm going lithium so Inverter is intended to be installed on my boat now. OK Issue..
I am intending to use a Rpi with Venus OS installed. The issue I have is when connected via the MK3 usb, the inverter will not switch on / off / charge as I understand it is meant to (via the Venus Web GUI)
The Multiplus is the older large EEprom (190xxxxxx) but I still believe it should work
If I try and control ac input limit or on / off / charge it comes up with the error shown in the images.
I'm running the latest firmware available for the version and it makes NO difference if I use the 1xx or 2xx firmware same error. If i check or uncheck override remote it makes no difference either. NO assistants are running
I'd like to know one way or the other if this will work, i intend to have a touch screen and operate it that way, if I cant do it that way i guess im back to an external 3 way switch. Im not convinced a digital multipanel would work.
Out of interest - if a digital multi was once connected - removing it flashing firmware a hundred times etc should remove any traces shouldnt it? are there any hard reset procedures I could use?
Thanks
Steve
PLEASE NOTE ANY WIRING SHOWN IS PURELY BENCH TEST WIRING :)
MultiPlus Quattro Inverter ChargerVenus OS
